Re: Force Impeller question
Since for correct operation the impeller must flex, as far as I know, NO manufacturer uses a stainless impeller. They are all rubber. Usually, they have a hard plastic or a bronze drive insert. It is possile that someone makes an impeller with a stainless drive insert and is calling it a "Stainless Impeller."
More likely, when Mercury started to change Force engines, one of the first things they did was to change from a cast aluminum water pump housing to a plastic housing. This housing has a slip-in stainless cup and could possibly be referred to as a "stainless" pump. This pump would have been used from around 1990 on.
You do not state the year of your engine, but if it is 1989 or earlier, chances are good that you do not have this pump. However: If your lower unit has a two piece drive shaft, then it WILL also have the plastic/stainless combination pump.
