A Florida boat, and sat for the summer, stored, with a almost full tank of gas, and blue sta-bil stabelizer in the tank. Prior to start for the first time, I changed out the spin-on water/seperator filter, drained VST,and filled it with gas/oil, also drained sm fuel filter, and bowl. Engine ran fine on start up and shut it off after a few minutes. Went to the ramp to run engine and would not start, just like it was out of gas. Got home, pulled return fuel line from fuel rail going to VST and no gas or anything while cranking the engine. Pulled hose from top lp pump and almost pure water came out, while pumping the ball. Had 5 gallon of water in main tank. My question is ,can water get through the fine screening mesh thats on the bottom of the high pressure pump? can the water get inside the engine, and how to I get it out? Bernie
