its a 1989 cobra 5.0 350 i/o with power steering (engine is removed new one waiting to be put in) and I couldnt get it to move at all trying it from the wheel so I did all the trouble shooting, cable greased and it moves freely when diconnected from acutator and the ram works fine when its disconnected from the tiler arm but when the arm is not attached to them its frozen so I found the problem now I have the out drive removed and have PB blaster the top and bottom swivel pins on the gimbal ring but she is solid no movement at all even by wedging it easy to the left and right Im thinking this must be the problem these two swivel pins...am I missing something else I dont want to snap the tiller arm etc off... I took the top long bolt off on the top(tiller arm ) and the 4 nuts washer off and sprayed down that but nothing,,,can I heat this up?? is there bearings inside this or just pins??? thanks
