I am currently fixing 2 out of 3 outboards that I have purchased for not much, they have good compression, good spark.
The 6 HP just have a new carb kit including a new float, and a new water pump impeller. Runs better now at lower rpm than before. But since all the lake are frozen, I can't go try the motor on a lake with so I have to run them in a big garbage can of about 25 gallons. It picks up a high rpm but it slows down not long after while in gear. Is this normal? The 7.5 HP Johnson is doing the same to.
