I bought a 1987 Wellcraft 265 with a Mercruiser 260 and Alpha outdrive and I am learning my way around it. With a fresh battery, gauges come on and I can operate trim a few times. At some point when I press the trim switch I hear the trim relay click and the voltage gauge will drop from 12.5 to zero and nothing works. If I turn off main switch and let it rest for 20 minutes it "resets" and will work again for a few minutes. I thought the trim motor was pulling too much amperage from the battery, so I jumped my running truck battery to the boat. Same thing. Main circuit breaker for engine is not tripped. What is tripping?
Can't find this problem in the forums; thanks for your help.
