I have a '65 Evinrude 6hp, received it from my grandpa last year after it sat for years without use. I rebuilt the carb last year and ran it with some intermittent starting issues this year. Put in new spark plugs during the summer, and last time out in October it started on one pull each time I yanked the rope. However I still planned on replacing coils, points, condensors, water pump, etc this winter due to the motor's age and for some fun.
I pulled the flywheel last night, and was quite surprised with what I found. The coils seem to be in great shape (not remotely dried or cracked), and everything under the wheel looked new. Only problem I came across was the points, as one of them couldn't be gapped, the adjustable part would not move far enough away from the spring loaded piece.
What should my next move be? I would love to keep this motor running for years, and I know the newer components are made of better more resilient material. I'll replace the impeller as it's never been changed. I plan on posting some pictures, but just not sure what my next move should be. With cleaned carb (should I do it again?), 90 compression in each cylinder, new plugs, and seemingly capable magneto parts I'm not sure why I ever had issues early in the year. Maybe the points/gap issue is something to look into further. Thanks for any advice or input!
