Was given this motor and there is no serial tags
Smokepole27
If anyone could help itd be greatly appreciated. Need to know around about year and model of this 35hp mercury 2 cylinder single carb. And If anyone wants to buy parts off of it, motor is locked up but Im sure there are alot of good parts still.
mjc3834merc
Re: Was given this motor and there is no serial tags
Somewhere on the cylinder block there should be a plug with the serial number on it. See pic. When you have the serial number someone will be able to tell you the year if you know the motor is a 35hp.
joed
At least post some pictures. From what you have given us so far there nothing to even use to make a guess.
Smokepole27
Opps sorry I thought I did.
79Merc80
My guess would be 1968 - 1971.
Craig
