Hi, I need advice to help diagnose a problem I have.
I had the boat out 1 week before this and experienced no such problems.
The motor started and idled fine, however 5 mins later I opened it up to about 3500 rpms and 30 seconds later the engine slowly stalled. It sounded as if it ran out of fuel.
Sure enough the hand primer was limp but wouldnt prime. On further inspection the external fuel filter had some water mixed/trapped in it.
I checked flow from the fuel tank to the external filter - OK. I could also prime from the hand primer to the inlet of the fuel filter on the engine.
I couldn't get it going so I took it home.
The fuel is good. I have now replaced the filter with a water seperator with clear bowl and installed a new hand primer. It starts, revs up and idles fine on the trailer with the hose connected.
The same problem has happenned again on the water.
Has anyone got any suggestions or diagnostic help please.
