series60
- Jan 4, 2010
- 420
Hi Guys,
I have a problem identifying for replacement, the trims hoses that came off my 1984 MCM228R. (Eng SN: 6811457. Transom assembly: SN 6771479). The leg has been changed out to a Alpha One. The trim pump is a Oildyne pump with medal reservoir. Manual says they changed to a aluminum reservoirs later in the manufacturing process. The problem is each of these hoses have a different length and bend on the ends and I can't tell which ones I need from all the pictures of these hoses in all the different online catalogs. All threaded ends are the same (3/8" I think) but each end has a little different length and bend. The length is 44" for the black one and 46" for the white one. I would like some input on which hoses to buy. I think these are the ones I need but can't be sure!. Numbers 18-2108 and 18-2109.
