Hi,
So I finally got my '88 50hp going.
Got a tank and a battery and built up anticipation and was sadly disappointed that couldn't start It. Then, the next weekend I was told that if when it is in neutral that I hold in the button called throttle only and push the gear full forward, it will start but will rev really hard so be ready to back it off. So I did, primed the fuel, turned the water on the ear muffs pushed the button, pushed the arm forward cranked the key...VVVVROOOOOM, wow much excitement.
Then I backed it off half way between full and neutral giving it a chance to warm up for a minute or two (done this more than once) But............... I can't back it off enough to get it back into ordinary neutral. I obviously need to get it back to ordinary neutral so the throttle only button pops out thus then being able to select forward or reverse. But when I get near to neutral it flutters and stalls. After trying a few times and expecting it should then be warm I tried to start it from ordinary neutral but won't start only when trottle only button is in and pushed full forward.
Any ideas.
Any ideas.
