Cant reach rpm at wot. Can only get 3100 on each engine. Suspect someone has changed props (do not match records). 16x 16 cupped now on boat. Anyone know what works with this combination? Need a place to start. Pflathead
I'm thinking with those props and that gear, you should be pretty close...<br /><br />Engines in tune, or tired out? That's a whole bunch of boat for a pair of 350ci/270hp Crusaders to push.. Bottom clean?<br /><br />Might try here and see if Michigan will spec out a prop size for you.. http://www.miwheel.com/MIWheel/PropAnalysis/InboardAnalysis/InboOne.asp
