nsfdfiremed
- Dec 1, 2010
- 2
I am new to this forum but it has provided me a great deal of information so far. Just two weeks ago I bought my first boat, a '94 Four Winns 170 Freedom with a 115hp Johnson. The boat is pristine, the motor was supposedly rebuilt. New powerhead, starter, water pump but the owner (who did the work himself) could never get it to run properly. I was told that it just needed a flywheel...yeah right. The boat is at a repair shop, I have been told that 3 cylinders have decent compression while the fourth is low. The head gasket was replaced. The original owner told me that the motor had grenaded which is why he rebuilt it. The shop is cautioning me regarding having them do a lot of work to it as it needs the carbs rebuilt, powerhead gone through etc..that this motor as it sits is likely a money pit.
My dilemma is should I replace this engine with another used rebuilt one or have this powerhead rebuilt, installed and set up correctly? I have found a '98 90hp Johnson, a '96 150hp Johnson ( I know about the over power insurance issues) and a custom powerhead builder that would build, install and warranty his powerhead for one year. Since the price on all these are within a few hundred of each other is there a real advantage in steering one way or another? The boat will be used on a small inland Wisconsin lake. Mostly for tubing, pulling a skier or just cruising. Also should I replace the VRO pump and update it or discontinue using it and run premixed fuel? Your expertise is really appreciated.
