Re: Your Opinion on Oil Injection
You do the math on the response. When you can it to WOT from idle, the right mix is getting to the carbs in 2/3 of 1 second.
You are off your rocker dude! lol!!! Time to get schooled !!!
Ok lets do this the hard way...
Because I have a Navman tracker with a fuel computer, I know exactly how much I am burning for any given speed.
On my '86 I6 115, I get 2.45 km/l @ 44 km/h best cruise. @ 3150rpm
That drops to 1.4km/l @ 85 km/h @ 6000rpm
My auto blender was mounted inside the boat next to the battery so It is not unreasonable to need 4 feet of line from it to reach the motor is it? In fact it was probably closer to 5 feet.
So assuming 5/16" line, lets calculate the volume shall we?
Volume of a cylinder= pi times radius squared times length
Converting 5/16" to mm we get 7.9375 mm diameter.
Divide by 2 to get radius = 3.96875
Square that to get 15.75mm
Multiply by 3.14159... and you get 49.483
4 feet = ~1200mm so multply that and we get 59,380 cubic mm
1 liter = 1,000,000 cubic mm
Divide 59,380 by 1,000,000 and we get 0.05938 liters volume in 4 feet of fuel line.
Correct?
Maximum burn rate @ wot once at full speed = 1.4 km/l @6000 rpm@ 85km/h
Divide 85 by 1.4 to get 60.71 liters per hour at full speed /revs. Lets just say 60 shall we?
That is 1 liter per minute.
=0.0166667 liters/ second
Divide 0.05938 by 0.016667
= 3.56 seconds just to travel the 4 feet of line at maximum flow
However, the amount of fuel that flows is proportion to the rpm of the motor and does not flow near that rate if you hammer dowm from a 600 rpm idle.
If you like I could calculate out exactly how much fuel that is used for each revolution of the motor, but the point is that it idles around 600rpm and dropping the hammer only gets it revving only 2000 rpm or so until it is out of the hole so lets say 5 seconds or so before it starts to spool up.
So the burn rate at 2000 is 1/3 the rate at 6000.
At that rate, it takes over 10.5 seconds for the fuel to travel just from the autoblender to the fuel connection at the motor.
Once there it still has to travel about a foot to get to the fuel pump.
The fuel pump itself holds an amount of gas that has to be accounted for before we can move on down the line to get to the 3 carbs so at least another foot of lines and more like 2.
Now right there, that almost doubles the volume of the 4 foot chunk of line.
Now we get to the carbs and the volume of 3 float bowls.
It think it would be safe to say that the lines, pump and carbs on the motor itself hold more fuel than the 4' foot line I have calculated the volume for.
Are you starting to get the picture?
At full rate, it takes about 10 seconds for fuel to travel from the autoblend and reach the cylinders.
Hammering down from idle will take much longer.
15 seconds is not enough, now that I have really thought about it.
In reality it is more like 20 seconds.
Please explain why you feel the need to spew bullship out of your blowhole J martin.
