K20-69-POS
- Nov 21, 2010
- 12
Im thinking about buying a boat, I've looked at a lot and many are $3500 or more for what seem like good running boats, my question to all of you is would it be worth it to fix the problems with this boat
http://delaware.craigslist.org/boa/2074929375.html
I can get it for $1000 and this is what the seller had to say about it:
"The boat is mechanically sound, the electronics are working, the floor
and transom are sound, the boat was fogged/drained and refilled with
RV-50 antifreeze, it could be restarted but if you decide not to
complet a sale I would charge you $50.00 to re-winterize. The
manifolds and riser are fine. Yes if you repair the seat bases and
replace the toggle switches at the helm that need replacement you
would have a reliable boat in the spring. I would also suggest
removing the fuel in the tank and refilling with new. The gas is
probably 2 years old and stale. Thanks for reconsidering."
Stuart
The other two I am considering would be both running, ready to go boats:
http://reading.craigslist.org/boa/2056880145.html --- for $3650
or A decent 241 four winns liberator that apparently has had almost 10 grand recently put into it, I can get this boat for $3600
Please respond as I will be making a decision by the end of the week!!
Stuart
