Re: Michigan Wheel Match
I use a 17 (for skiing) and 19 pitch (for cruising) on my Chrysler. I believe it was originally a Mercury prop. The splines are the same and those with hubs to fit small gearcase Mercs will fit late model Chrysler and early Force engines.
It is a well made prop, It comes cupped standard, aluminum is not. It runs about 200 RPM faster on my boat and it holds the water better than a stock aluminum prop. It won't make your engine a "fire-breather" but will perform quite nicely. I'm very satisfied with mine.
170? Why? Are you sure it is stainless? Aluminum is 178 bucks. IMHO: At 170 with shipping included, it is worth the expense.
