Hi guys
just looking to see if anyone can help
Have a 2003 250 EFI Merc - was on a boat i bought offshore so i do not know its history.
its done 450hours and is not running properly at idle up to 2500(ish rpm) above that runs fine.
So far we have-
full serviced (water pump/impellors/filters/plugs -plug gap tested etc)
replaced a faulty coil the others were tested as fine
Spark and fuel is good on all cylinders
compressions are good and even on all 6 cylinders
all fuel injectors serviced and tested
ecu tested and ok
run the boat under load - and pulled off every lead and put back on -no difference to problem
Ran on seperate fuel tank (to elimante a "bad" fuel prob)
Any ideas would be welcomed!
regards
Bill
So far we have-
ecu tested and ok
regards
Bill
