I had a reversible motor that needed some help to start by turning the belt wheel manually, and blew a circuit breaker after 10-15 seconds. I swapped out capacitors and it seems to work fine now. Do capacitors cause problems like this?
Another motor overheats in about 20 seconds a blows a circuit breaker. Would a capacitor have anything to do with it. It worked fine last spring, but this problem came up when it was used again this winter.
Thanks.
Thanks.
