I have a 20' Sea Ark cc boat with a 150 hp Suzuki four stroke motor, the boat has a 15 degree hull, with a 72" bottom and weighs about 2860 lbs with motor, fuel, passangers and gear. I have a 3 blade Suzuki 14 3/4 X 23 propeller on the boat presently. I'm not completely satisfyed with the performance of the boat, I can just get 5000 rpm out of it. Also the propeller is extremely thin at the edges, I use the boat to fish redfish in shallow ponds. I have had to rebuild the prop three times in the last two years. Can someone suggest a prop I may be better satisfied with.
Max3812
Max3812
