Re: cleaning carb. tips
combustion chamber cleaner will get stuff that weak dip solution wont touch and still wont hurt plastic or rubber carb parts.
years ago the dip solutions were nasty enough that if it got on your skin you had about 20 seconds to get it off and cover it with oil or the skin would actually crack.
now I can use most of it as shaving lotion.
however years ago if you got it on plastic,rubber,paint, the coatings and epoxies most outboard carbs used, it simply dissolved it.
thats why most manufacturers specifically reccomend NOT to use a dip.
