Too Cycled
- Oct 24, 2010
- 24
I have a QD 20 I acquired to do a rehab on.
After a carb clean out and high pressure air blast through the jets, replacing the coils, replace recoil and water pump I tried a start-up.
It starts with some effort but runs reluctantly before gasping out. My guess is it is likely needing parts replaced in the carb or at least, more attention in that department.
What I am wondering is why, after only a few minutes of running, the water in the pail was black with oil (or carbon), the smoke was one puff away from signaling the fire dept. and most alarming, the gas tank was full of exhaust when I opened it.
I understand the engine produces the pressure that works as a fuel pump by pressurizing the gas tank but I can't understand why exhaust would be in there.
Is this not potentially One Backfire Away From Being A Bomb!
Any thought appreciated.
Cheers,
Kelly
Cheers,
Kelly
