dingbat
- Nov 20, 2001
- 17,285
Currently running a dual battery setup with a 3 way switch. Been working well for quite sometime but getting tired of messing with the switch and will install the Blue seas Add a battery kit.
Both batteries are Grp. 27 deep cycles. The switched ?boat? accessories are currently wired to the com. post on switch.
Battery 1 supplies the auto bilge pump and a helm mounted distribution panel for non-critical electronics, i.e. CD player, back-up VHF.
Battery 2, supplies a distribution panel in the overhead electronics box for critical navigation devices. GPS, radar, primary VHF and fish finder.
My question. Should I remove the direct feeds from both batteries and connect them directly to the com fed on the new switch? Leave the feeds where they are?
Suggestions for connecting the boat accessories wire(s) to the switch. The switch has a ? ? dia. post and the boat accessories connections are a couple of #10 rings. Don't want to put a bus bar in for a couple of wires unless I have too.
