kfa4303
Banned
- Sep 17, 2010
- 6,094
Hi all. So after getting my new/old '61 QD-22 10 hp up and running again.....Well I had it running anyway. Got it to fire up last night, then went to "fine tune" the carb today and opnened up a whole can of worms.
After many, many tries I eventually got her to fire up again, but she would only stay running when the throttle in the "START" position, but if I come off the throttle into the "SHIFT" position she konks out :/ I tried every combo of needle settings, but can only get it to fire once in every 40-50 pulls. After all that I figured it was a fuel/carb issue.
So I figured I should start over. I re-rebuilt the carb, which is now emaculate, added new plugs, new gas, re-gaped points, new impeller, etc......Once she's running she's smooth, but will only run at fairly high rpm in "START position :/ I've tried tweaking the hi/lo needles once she's running, but every time I decrease the throttle she dies and it takes many, many pulls to start again. As it is I have the hi speed (lower) needle out 3-4 turns (a lot, I know) while the lo speed (upper) needle is only out about 1/2 turn. I know those aren't "right", but it's the only way I can get her to run :/
Help!!!! I'm desperate.
