Re: wire harness????
This is what the guy told me with the control you showed me is he right?
the year was from a 1994. However, the control uses cables that have been in production since at least 1976. So as far as control cables it will work back that far. Electronically (the key switch) is of the newer style (mind you it does not come with the wiring harness, only drops that connect to it) which means it uses deutch connectors not the big round red connector that OMC used. But, there are harnesses availible for this control box that convert to either or. So weather you have a 1976 70 hp or a 2010 115hp E-Tec, you can use this box. Its all a matter of what harness you use / need.
