Here's an odd (I think) problem I encountered today in the first time afloat in my new (to me) boat.
94 Johnson 50 hp. Had trim cylinder resealed prior to putting in the water for the first time.
The unit will trim against engine thrust at full throttle but will not trim back down until the engine is at perhaps half throttle as in a situation requiring trim down to reduce porpoising. Also, it will not hold against the reverse thrust when backing off the trailer with any significant engine RPM in reverse.
Otherwise it seems fine. Doesn't bleed down under thrust and seems to function fine otherwise.
Ideas?
Steve
Ideas?
Steve
