Hello, I have a 88 baretta, 5.7 with a 280VP. I recently replaced the intermediate shaft bearings and bellows.Took her out for a test drive tonight, and everything went fine except little problems. My shift cable is sticking and when put into gear, the gears are slamming. Think that it may be binding somewhere? My 4 barrel carb is popping at about 2,000rpm and seems to be choking out, but runs fine at idle and light acceleration. Also my tilt is not operating all the way up, which I think may be cause it needs fluid and I dont know where to install the fluids and what type of fluid it needs? Can help me get these little problems worked out, or at least point me in the right direction? Trying to make it to saltwater by thankgiving. Thanks
