bear_69cuda
- Oct 10, 2008
- 2,109
Gang,
rodbolt...
I just wanted to thank everyone for helping me though the winterizing/fogging process, I really respect and appreciate all your help and expertise! iboats is a really great thing!
Finished winterizing my F150TXR, vst drain/fill with remote mix, new cup filter, new H20/fuel separator, remote tank fogging 20 min at idle on muffs, gear oil change, lubed all Zerk's, lube prop shaft, oil change/filter, removed oil with vacuum suction tank (very slick!), removed plugs sprayed cylinders with fogging oil, turned engine over with no spark to distribute fogging oil, stabilized fuel, filled up with no ETOH 92 octane.. All fresh H20 tanks/lines filled with pink RV. I'm ready for storage... :redface: Good and sad at the same time.. The season is finished....
Thanks again!
rodbolt...
Thanks again!
