When I first got this motor, it did not have spark. Cleaned the points and ohmed out coils, still no spark. I then unhooked the kill switch and tested it, its working, normally open. I then hooked the kill switch wires from the mag together and got spark. Makes no sense, if the kill switch is normally open. Anyway, go out the next day and no spark again with nothing touched. I then figured maybe a condensor was bad, so I put a complete tune-up kit in it including plug wires, still no spark. The coils look new, they are red with the OMC P/N 580416. I got 6700 ohms on one and 7000 ohms on the other. I also checked the primary side and got .001 continuity on both. Could these coils still be bad?
