Aq125 is marine version of what auto motor
Old85
Ive read elsewhere that the AQ145 was based on the volvo b23 auto motor....
Does anyone know what automotive model the AQ125 was based on? The same or another one....
Re: Aq125 is marine version of what auto motor
Ayuh,... If you're talkin' about a little 4 cylinder overhead cam motor,...
I think you're Correct....
captmello
Yep, same block. AQ145 was the twin carb model.
adeneo
Aq120, AQ125 and AQ140 = B21
AQ145 and a few others = B23
Pretty much the same engine, but just to be accurate!
Here are the specs, the main difference between the B21 and B23 is the bore!
Stroke: 80 mm (3.150 inches)
B19 bore: 88.9 mm (3,500 inches)
B21 bore: 92 mm (3.622 inches)
B23 bore: 96 mm (3.780 inches)
Con-rod length (c to c): 145 mm (5.709 inches)
Crankshaft main journal diameter: 63.45 mm (2.498 inches)
Con-rod's bearing's journal diameter: 54 mm (2.126 inches)
Wrist pin diameter: 24 mm (0.945 inches)
Piston height:
B19A: 46 mm
B19E: (->1983) 46 mm
B19E: (1984->) 46.7 mm
B19ET: 46 mm
B19K: 46.7 mm
B21A Europe: 46.7 mm
B21A: 46 mm
B21E: 46 mm
B21ET: 46.5 mm
B23A: 46.4 mm
B23E: 46.4 mm
Firing order: 1-3-4-2
Fun Times
Nice!
Adeneo, Are you a volvo auto tech?
adeneo
No I'm an expert
tech :eek:
Seriously though, I work with boats, but english is not my first language so I try to refrain from answering as there are many others on here with way more knowledge then me, and better english skills :confused:
No I'm an expert
tech :eek:
Ayuh,... Google Tech,... :D I love it,... just spit on the monitor.... :D
Your english looks pretty darn Good from here,... ;)
