I have an oddity of a boat, it's a 2000 Maxum 1900SC Cuddy with a 80's volvo AQ131a and 275 Drive.
My stock aluminum 3 blade 14x17 has been slowly losing speed this season, seems like I'm spinning more rpm to go the same speed. Not alot but enough to notice like 1 to 1-1/2 knots. Slip is awful, calculated at 29%.
My specs are:
19' long Cuddy cabin boat, 15* semi deep-vee hull.
Stepped transom(swim platform is molded in)
130HP 4-cylinder AQ131a OHC I/O
~3500#'s fully loaded with people gear and full fuel
I cruise at 4500rpm seeing 21kts, and WOT at 26-28kts depending on conditions at 5350 rpm.
Getting 4.2mpg.
I have 60# smart tabs set on hole #5. Hole 4 and 5 work great, hole 3, and the boat starts to porpoise a little bit.
My drive ratio is 2.15
I have a 9.8HP kicker on the back(reason for the tabs-weight hurt performance and getting on step). It planes easily with them, I'm up in about 5 seconds.
I'm looking for a few more knots at cruise, and to wot at around 5000rpm. A VP 14x19 3-blade leaves me 200rpm short of wot spec. I want to stay with aluminum props to protect my drive. I've seen several change to the solas amita 4-blade and see better results all around. Is a 14x17 4-blade going to be the ticket?
My specs are:
Getting 4.2mpg.
