I have inheireted a basket case 1999 25 mercury, The s/n on the mid section does not match the s/n on the block,Is this normal? The s/n on the block is og021968(NO MERCOSIL STAMP), I see that there are two different types of cylinder material with different pistons and rings for them. I have a set of OEM pistons that I cleaned up and measured that are in good shape. My question is are these the correct pistons for this block? The block also measured out standard and in good shape. The casting #'s on these pistons are 767-9014a15.
