I saw in another post where someone mentioned changing the fuel pump on a 1980 50 hp motor. I may be blind or ignorant but where is the fuel pump? I looked between the bulb and the carbs and I do not see one.
My motor will start up fine but will die after about 30 -45 seconds of idle unless I pump the bulb. It also dies if I shift it into Forward and put power to it.
Thanks.
Thanks.
