Will a crank from a '94 v4 work in a '89 block ?
jim kinser Petty Officer 3rd Class Joined Nov 17, 2007 Messages 94 Nov 16, 2010 #1 Will a crank from a '94 v4 work in a '89 block ?
E emdsapmgr Supreme Mariner Joined Dec 9, 2005 Messages 11,551 Nov 17, 2010 #2 Re: crank cross It is very possible that you can swap them. Even though the crank part numbers are different, both cranks share the same bearing part numbers throughout-even the same flywheel key.
D Dhadley Supreme Mariner Joined Feb 4, 2001 Messages 16,978 Nov 17, 2010 #3 Re: crank cross Which V4s? Are both cranks from a crossflow? Both from a looper? A crossflow and a looper crank are very different and do not interchange.
jim kinser Petty Officer 3rd Class Joined Nov 17, 2007 Messages 94 Nov 17, 2010 #4 Re: crank cross Both engines are crossflows, the only difference I can see is the '94 has a different lower seal.
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Nov 17, 2010 #5 Re: crank cross The upper d/s seal areas were different between the years. You may have to do some lower crank case head swapping.
jim kinser Petty Officer 3rd Class Joined Nov 17, 2007 Messages 94 Nov 19, 2010 #6 Re: crank cross Found another crank in my junk, this one is the same as the original. thanks
