Re: timing light questions
An inductive pickup (non contact) is a coil of wire enclosed in a clamp that creates a field to sense the current (spark) going through a wire it inturn triggers the timing light to flash each time the spark is sensed, and yes it's the same as any automotive timing light. It'll have the pick up clamp and leads to connect to a 12 volt power source (your battery)
