i have a 2 cycle yamahaa 115.the volt meter works fine when the key is on.when i start the motor it will go on and off at random.all the gauges go off and on.it does not effect the battery charge or the running of the engine.
thanks, bob
Ialso noticed the volt meter makes a winding buzzing noise when it goes off and on.checked all the fuses and wiring and could not find the problem
thanks, bob
