bob johnson
- Feb 25, 2009
- 4,304
motor shakes and breakes up above 2600 rpms..purrs like a kitten up to 2500 rpms...2500 or less all vitals are good water pressure 20 psi, water temps 120 in both heads...
what happend...is two scenarios
was running all day great , i was running down river at 4500 rms for about 2 miles...watching for debris in the river and for birds on the water..also watching a huge barge i was passing...so i wasnt watching my guages...
when i came upon a large area of logs i slowed, but it was too late to avoid them, and i went over a long log. I felt it hit the boat, then the lower unit, then the prop..
I was only doing about 2000 rpms at the time.. then I throttled back up wondering if I did any damage..so after about 30 seconds i glanced down at the guages and I was 220 degrees in one head and 200 in the other!!!!
I quickly idled down..and in about 30 seconds the temps dropped back into the 120's.
so i throttled back up and the motor started shaking badly....I idles down...
temps were good...it ran great under 2500 rpms..but If i tried to go 2600 rpms or more ...motor shook and bucked...
I ran all the 2 more miles back to the ramp at 2000-2500 rpm...purred great...
checks i did this morning...after i got home..
spark is great in all four cylinders.
compression is 120 125 130 130
the prop spins perfectly true...no wobble at all...
thats where I am.... wondering...what can cause this shudder and shake violently above 2500 when all vitals seem ok...
dont know what caused it...the log or the high temps...
STRONG water pressure!!!
any ideas where to start looking??
thanks
again 1995 johnson 60 degree lopper V4 ocean runner... spark plugs are dark oily.....stained..brown...but no build up...
I always run extra oil
bob
thanks
bob
