icdeadfish
- Nov 3, 2010
- 3
help, help ready to do the waterpump again bottom of impeller 1/3 up gonefound pieces in block when tore it apart also found pieces of rings and the part of piston between rings missing on #1 & 4 have a used powerhead coming but the problem I have is the black washer almost like a garden hose washer not sure if it goes on top of water pump on driveshaft or there is a small space between the plastic pump housing and the metal sleeve that the impeller fits in the diagrams on line dont show detail that good. Also a tip I learned hard way after trying to trouble shoot my missing engine problem thought i figured it out i pulled plug wires 1 at a time #4 made no difference so I thought it was a trigger problem took it to shop here in Santa Cruz to see what it would cost to fix problem get call hour later come pick it up they thought I sucked in a reed in #4 since they pulled the head and saw some damage to top side of piston handed me me head and a bag of head bolts and charged me 200 bucks for the bad news and said that it would cost 4 to 5 thousand bucks to fix. my lesson learned do a compression check dont assume it is spark only. sorry the message is so long for my first post but need to vent had the bayliner since 1995 and a lot of lake trips and salmon trips and my biggest 32 lb 3 years ago I hope the used powerhead gives another 10 years of ($$ JOY $$) FISH-ON last Im not sure if I paid attention to direction of impeller when i install them I will this time with dishsoap thanks to one the generals replys good day
