My 35' sailboat had her hull stripped down to the fiberglass so I could redo it. My nephew was helping me and we began with a barrier coat of Interlux 2000e. We has 2 coats on and quit for the night. As I was cleaning up I noticed my nephew didn't mix a good inch of the hardener in the gallon can for each coat. After that I did half of the hull with the correct mix but stopped cause I'm afraid that the first two coats will not create the proper bond to the hull.
Is this going to cause problems down the road? Everything appears ok with the correctly mixed batch, do i continue on over the two bad coats?
Any thought are much appreciated!
Karen
Karen
