dragonfly 200
- Sep 24, 2010
- 30
Not a good day, my rude has been hard to start first thing in the morning but usually once you get it going it would start everytime during that day. I was thinking maybe it was flooding because when it would start it would smoke bad. Been having idling problems and would sometimes stall, I have been trying to track down that problem. Today she would not start, brought it back home pull a plug wire and put the spark tester on it, great spark, put it back, cranked it in the yard it backfired and acted like it was going to start, went back down put it over and fired a couple of times but did not start, then nothing, stopped and gave it a minute and it started with the warm-up lever up, I pushed the lever back down about half, it was run rough and missing, I pull the lever back up and it did not increase rpm's, so I tried to pump the bulb and no change, then came the white smoke out the exhaust, I immedately shut it down and then saw smoke coming out of the cowling, pull the lid and FIRE coming out of the silencer, grabbed the fire extingusher and had to shoot it twice to get it out.
Got it back home and took the silencer off and found the fire had started somewhere in the bottom, it appeared worse around the primer solenold.
Could the power pack have cause the backfire and the hard starting??
I have a lot of work to do!! three lower carbs toasted and all the primer and fuel lines. I want to make sure this does not happen again. Everyone kept telling me carbs dirty, I took each one off and cleaned, no kits, all gaskets, seals and needles looked like new. Compression was 80psi all the way around.
Should a backfire cause the thing to catch fire?? My next purchase is the factory manual, 2nd, new fire extinguisher. I hope this will remind everyone to check your fire extinguisher. Once I get all the damage fixed, should I replace the power pack??
My fall fishing season is over
Dragonfly 200
Dragonfly 200
