I just purchased a used Johnson 1990 115 Hp V4. My old V4 was a short shaft, while the engine I just bought has a long shaft (about 3 inches longer). The guys at the shop mounted the engine about 3" higher on my transom so the trim and tilt bracket hooks are not hanging on the transom, but are about 3 inches above it (the fin at the bottom of the lower unit is still about 1" lower than my old unit). The engine is mounted to the transom by 4 bolts. Is this a problem or not??? In the water, if I don't trim my engine down all the way, a lot water will splash into the aft part of my boat and actually fill the area at the back on my boat! It also seems like there is a lot more drag than my old motor. Also, my wake isn't as clean as my old short engine. Should I lower the engine on my boat? If I do it seems like there will be more drag with the lower unit of my engine.
