Re: water pump test?
Impellers are designed to be in contact with the housing AT ALL TIMES except for what may be considered a microspacing where water lubricates the contact between the housing and the impeller.
You would notice that the hole in the housing is not centered. In each rotation of the pump each vane moves from fully bent to extended to the max allowed in the housing, as they move from the area where the hole is close to the walls of the housing toward the further area.
As the impeller rotates the vanes move from bent to extended, and the increase in the volume of the space between the vanes, creates the suction that causes the pump to suck in water. as it continues to rotate the vanes begin to bend as they go back into the smaller area, here the space is once again reducing, resulting in the water being squeezed out of the space.
AT NO POINT IN THE OPERATION OF THIS TYPE OF PUMP DOES THE IMPELLER WORK LIKE A CENTRIFUGAL FIXED IMPELLER PUMP.
If the impeller is realy old parts of it would remain in the fully bent position so no longer providing a seal against the housing walls to allow the suction or squeeze out effects, thus resulting in an inefficency in the pump. at this point the pump tries to act as a fixed vane pump, and since its housing is not designed for this method of operation, it is ineffective and the impeller must be replaced.
To the OP if you run on the muffs for a while with good water pressure it should indicate that you would get good performance in the water, as the rpm and associated heat creation increases so does the water supplied by the pump. however if the rpm is increased on the muffs, it would reach a point where the hose would not be able to supply the required amount of water for operation. Causing engine overheat.
this however is dependant on your proper inspection of the housing as per the manual and installation of the impeller likewise.
cheers
NO Fuss
