Hi everyone.
Got a line on a first boat. 98 Excel 175SX, 4.3 merc, alpha 1. Reasonable shape for the age, priced below NADA. Rural area, must sell, needs money. I took a first look at it recently. Found a few issues but nothing that seems serious.
Exhaust boot is torn all the way through although it was replaced this past summer. Looking into warranty on that, or I'll have to replace it.
Hydraulic trim line is leaking in the engine compartment, needs to be replaced. Any insight on that? Wonder if it's an age thing or something else. Might need to do both lines there?
The anodes are half to 3/4 gone. Is that normal or should I be looking for an underlying problem?
The interior is in decent shape, some parts have been replaced or recovered. I noticed that the carpet/liner in the side wells is peeling back from the sides at the top. Might that indicate any sort of problem? The fiberglass underneath seems solid. I assume some cleaning and regluing will take care of that?
There's a couple of scrapes on the keel that I assume should be covered over. Any thoughts on how to do that?
Engine runs good but is a bit hard to start cold; not enough fuel. starting fluid fires it right up. Choke closes but it's still cold-blooded. Runs a bit rough cold too. Smooth enough once it gets off idle or warms up. Might need a carb O/H which I can do.
As a retired auto mechanic, I can do most of the work myself. I'm planning a compression test and full function test later this week. Anything specific to look for?
What are your thoughts on this particular year/model? I want a fish/ski style for use on the Colorado river and Lake Mead/Mohave. Mostly fishing and some river running.
Oh; speaking of fishing, any comments on mounting a trolling motor?
Thanks!
Charlie
Kingman, AZ
Thanks!
Charlie
Kingman, AZ
