Re: 19ft Cobalt with 351w
Sure thing. I am giving you a rough estimate based on my boat because they are VERY similar. The Cobalt has a slightly deeper V, but they will be pretty close in length and weight/engine type. I haven't done a WOT test on my newly rebuilt 351w, so I can't give you accurate info on that. I had the Merc 233HP for the numbers I gave you which is with the 2bbl carb. I now have a 4bbl carb and slightly more efficient exhaust manifolds, but I don't expect to pick up more than 2-3mph at the most on the top end.
Speeds were also taken from the stock pitot-style speedo, but it always seemed to be relatively accurate.
