Replacing the floor in my 17ft lund with new plywood, which will be coated in epoxy & glass. The OEM carpet was similar to indoor/outdoor variety with some type of rubber backing and glued to the plywood. I do not want to replace all of the carpet in the boat, and the closest match I could find was artifiical grass carpeting from http://boatcarpetoutlet.com.
It arrived today, and looks like very "basic" stuff with stiff nylon backing. Based on the fact I am sealing the floor with epoxy & glass, does it really matter what type of carpet is used (other than wear factors)? I assume it is best to use a marine type glue to stick it to the floor?
Since I am going though this much work, I want a decent end result that will hold up well for at least 5+ years.
Thanks!
Thanks!
