sechristmas
- Nov 7, 2010
- 2
Lower unit is off motor and is stuck in forward gear. I had removed the small pivot pin on the clutch dog lever which started this whole thing. Got it back into place but it still is stuck. When you pull up down on the linkage it doesn't help or move much....any ideas? I think it has to do with the clutch dog lever pin I removed.. is it possible not to get it back into place correctly?
Thanks.
Thanks.
