I have a 1992 Evinrude Spitfire 150 hp on a 1979 Chaparral 21' Cuddy Cabin that I am in the process of refurbishing. The boat originally was equipped with a 1979 200 hp Evinrude and was repowered in 1992 with the 150 Spitfire. I bought the boat with the engine "blown" and have determined that the #2 cylinder on the port side is indeed destroyed (I can push a magnetic probe through the piston into the crankcase and bring out pieces of bearings, etc). My initial thoughts were to repower with a newer used/reman motor, but my local marine mechanic said that I would be money ahead to rebuild the motor I have. I really don't know much about this motor. The mechanic says that this motor is "stronger" than the older 200 hp Evinrudes and would be worth rebuilding, he says he can do it for about $2500. I have no idea if this is enough power for this boat (plan to cruise, no water sports) or if this is a motor worth rebuilding. Any thoughts on this are appreciated.
