sublauxation
- Oct 13, 2008
- 1,317
Funny how one things turns into another, I want to add a windshield to my dual console 18' aluminum boat. As long as I'm doing that I figured I'd fix the consoles....which leads to redoing the front casting deck, and part of the floor. So as long as I'm at it......
My question is, now I have 1 trolling motor battery up front and the starting battery about 2 feet up from the transom. I have no problems with getting on plane, boat seems to float well, but is there any logic to moving the back battery up in the front where I could build a nice storage area for both batteries side by side? The current rear storage would be great for easy access to lifejackets etc if there wasn't a battery there.
If I put both in front it would be right next to the controls and probably 10 feet from the motor.
Is there any problem with setting the batteries right on the aluminum below the false floor, should I put some sort of rubber to insulate/reduce vibration?
