Re: Confused 115 in a 90?
there are a few reasons this could be the case.1)its a "frankenmerc"motor.Simply stated,someone built the motor from parts of other motors.2)the"need for speed" kicked in and so they put a 115 on it and changed the decals to follow the recommended hp rating of the boat.Is it rated for 90hp max?Or 3)and Im not sure of this but block may be the same for yr range in question.Maybe he blew the 90 and since block was the same he just used a 115 block to save money(found one cheap).No matter what the reason for this,I sure hope you water tested the boat/motor before buying.Lots of "mercury wizards"out there but VERY FEW know what theyre doing.Hope it wasnt someones"hey,Id like to rebuild a motor to see if I can"project.Not saying a newbie rebuild is out of the question as possible.Just hope its the decal scenario,for you.
