The Big LO
- Nov 6, 2010
- 6
I have a newer minnkota trollling motor that just stopped working. it happened right after two things. One, i ran a manual bilge pump off of the same batter that runs the trolling motor. then the next morning my friend used the trolling motor to hoist himself up onto the boat as he was pushing it away from shore. So i'm wondering if either of those two things had something do do with it or what. The pedal makes the motor spin around all day long but the prop won't go anywhere. Sometimes you see a very slight start of a rotation like it's just starting to, but really it just moves 1-2 cm. It has a full charge to both batteries. any thoughts on this? is is possible for a fuse to be blown somewhere that would let the motor spin around but not let the prop spin? any help would help.. thanks!
