Re: 92 mercury 150
try spraying some premix in the carbs while running in forward gear and see if it picks up, you might have a weak fuel pump.
Gotta keep throwing possibilities out there until we eliminate them all and solve the problem.
Have you watched the throttle/shift cables operate their respective linkages to make sure your getting the proper amount of movement?
I'm not that knowledgeable on outboard ignitions, but I wonder if there isn't something with the stator that was an issue originally, that is still an issue... Crossed wire? Any chance something is causing one of the switchboxes to cut out in forward?
Could be that you ALMOST got it fixed, but something minor is eluding you, like a ground or something rubbing because it wasn't put back EXACTLY the way it was designed. Not being there, one can only speculate.
