FWC Custom Fittings/Hoses (recvd end cap)
FreeBeeTony
OK....here goes....<br />I am installing a FWC system on my Mercruiser 165 IL6. I am piecing together a system from parts found on ebay and such (with alot of help from bondo!). I will not be able to use preformed hoses. I am thinking of using copper and sweating elbows and other connectors to make some of the connections. I was also thinking of using PVC to make "step-ups" or "step-down" adapters if I have to go from on size hose to another. Would the coolant "eat" the PVC?<br />Any other ideas out there?
Re: FWC Custom Fittings/Hoses (recvd end cap)
I mentioned this in your other post, <br />By inserting coil springs of proper sizes, You Can bend a hose to fit your needs, Without Collapse........<br /><br />
Some of this Might be Necessary,<br />But, Long runs of Copper Tubing is Very Crack Prone, due to Vibrations + such.....<br />
This is where you'll want to swet up some copper/brass Fittings.......<br />
the 3 hardest words for a man to utter.....<br />I Don't Know........ :D
FreeBeeTony
Where can I find these springs? How tight of a bend can I make? The return from the H/E to the circ pump is kinda close together. I am going to have to make a 'S' shape.
At a Better Hardware Store ?????<br />Off an old Bedspring ????<br />Off Your Frontdoor ???? <br />Etc.????<br />You have to figure out what Dia. First.....<br />
As Tight as the Spring will Bend.......<br />
Tony, Forget about the Cir.Pump......<br />Your Cool-Water return to motor line will attach to the Same Fitting that Is the Outdrive Feed Line in your "after" link.........
FreeBeeTony
bondo....why shouldn't I connect the H/E the way it is shown in the manual (except that I will add the manifold into the freshwater path)? I don't think I will get the proper flow if I just replace the existing "in" and "out" of the raw water with the H/E. All of the diagrams show the H/E connected to the circ pump and the output from the thermo housing going to the manifolds...and back to the H/E.
navigator336
Ethylene glycol (standard anti-freeze) and Propylene glycol (Sierra brand enviro-friendly)are not very reactive chemicals. However, I couldn't find their effect on PVC listed in my tables. I would avoid the use of PVC with hot water though. You should be able to buy bronze fittings to adapt to various hose sizes easily. You could also find nylon fittings which are much more chemical and heat stable than PVC. <br /><br />Make sure you use stainless springs. You can wind your own on a lathe around a dowel of the right size. If you do this, use stainless spring steel.
You Can............ :) <br />Where are you going to add the manifold circuit ????<br /><br />Look on page 349.....<br />The T-stat housing you have Now, does the Same Job....<br />The circ pump Only moves the water Allowed by the T-stat.....<br />While the T-stat is Closed, water is allowed to move along the manifold,+ return to the H/E.....<br />I Think , If you use the dia. on page 356,<br />The water Can't move,+ the manifold is going to get Hot... Before the T-stat opens.....<br />By using the by-pass T-stat housing, Convection, along with 1 or 2, 1/8th" holes drilled in the T-stat shoulder, will help cool the manifold, till the block heats up....
FreeBeeTony
I plan on ading the manifold to the output of the thermostat housing, this is where I was going to tee-in the bypass so the manifold would get some flow before the thermostat opened.
That's my point...... ;) <br />Using the dia. on page356,<br />There Is NO By-pass.... NO Water Flow.....<br />As long as the T-stat is Closed, the water is Static.... No Flow.......
FreeBeeTony
The thermo-housing I am using has a bypass.
Hey, <br />It's Your Call..... ;)
FreeBeeTony
I don't think the flow or cooling capability would be the same by putting the H/E in place of my raw water connection that I have now. The manual shows the H/E before the circ pump and after the manifold......I hope your offer still stands on the end plate! It's supposed to be 45 here on Saturday and I am going to get under the cover and take a measurement.
Not a Problem Tony.......<br />If you study the dia.s on page 349, lower left side of the page shows that the T-stat you have Now, Actually Feeds Water Directly To the Pump..... It's a Straight Pass Through Port....But Still Allows for flow thru the manifold....<br />You Already Have the Flow Patterns you Need.....<br /><br />Like I said, It's Your Boat... Do Anything You Want..... I'll Still be here for Support..... ;)
FreeBeeTony
ok bondo, I measured the end cap.<br />The bolts appear to be ~ 3" on center. Let me know if you have one..........or else I will have to find another one.........I like the idea of the end cap instead of the nipple....<br />Thanks again.....Tony
airman
If you go to a good hose shop (Greenline in my area) you can get a variety of preformed hoses. IMHO it's a slightly better way to go than the spring trick, although I've seen both ways done well.
OK. Tony.....<br />I'll be out in the shop a little later....<br />If it appears to be the same, I'll take it off,+ Box it for shipping.....<br />I can mail it on Monday.....<br />If it's what you Need, You can send a Donation to the "Shop Beer Fund"........ :D
FreeBeeTony
Thanks Bondo..........that would be great!<br />I temporarily mounted the H/E and took some pics....I am going to add them to my web site....I'll let you know when it's ready to view!
OK Tony....<br />I've got this end-cap.....<br />Measures 3"X3" center to center bolt holes......<br />Measures 3 3/4s"X 3 3/4s" Overall........<br /><br />Email me at<br />Send me your postal address.....<br />In the Subject line type,"BOAT MANIFOLD END CAP"...<br />Use All Caps, that way I Might find it in All that Spam in that mail box.......<br /><br />I'll try to get it headed your way on Monday.....<br />Nope, make that Tuesday...... Holiday Monday....
Hi Tony,<br />Have you recieved the end-cap yet ????<br />I was looking up some parts in the NAPA cat., and happened to notice that these are still ava. from NAPA.....<br />Part # 18-4009, $62.10 list.... $40.04 My Cost.......<br />Gaskets are #18-1210, $1.00 list... $.55 jobber.....
FreeBeeTony
Hi bondo..........<br /><br />Nope...didn't get it yet...was hoping to get it today so I could play with it.<br /><br />I also saw them online after you sent yours! You have click on the inline 6 link and then scroll down the page. They also have the plate to block off the manifold from the elbow and the gaskets.<br />I will let you know how I make out. Thanks again!
